Progressive Alcohol Controller..making a small anouncement..
Beta testing the controller.
Heres an update on what and how..
Runs of the GN two bar factory MAP sensor, delivers 100 percent power output to the pump, and will eliminate the following symptoms
surging, black smoke, knock retard when boost is flashed..like when spinning tires in water. no more hobbs switches.
Here is some data..Been in my car now two weeks..so far so good. The following values are real life in the car.. not on a bench or.. was fun getting the data..
Alky pump pressure in PSI....boost
0...........................................0
12.5......................................3
25.........................................5
37.5......................................8
50.........................................10
62.5......................................12
75.........................................13.5
90.........................................15
This is using the SMC kit..that little pump rocks..probably get 100 PSI. with 14.volts on the pump. The 90 psi was with 12.26v ..need one of them volt boosters
Will work on any pump..actually was testing using a big tire inflator motor..so 25 amps are no problem.
Couple more weeks before ready for sale..other items is to make a display that runs of a pressure sender..whereas you see a an LED bargraph that corresponds to pump PSI.
And the I dont want Ninja death speed out of the controller.. I personally like 100 psi..but others dont..that is being addressed at this time.
thought I drop my Buick bretheren a note
Cheers
Julio
Cheers
Julio
