Typically we would ask for the measurements of your P-trim wheel. If they match our P-trim wheel measurements, and the housing bolts onto the bearing housing the same, then it should fit.
Our P-trim wheel measurements are 2.920" inducer and 2.542" exducer.
Hope this helps.
Patrick
depending on ypur combo a .63 might spool to fast. Case in point friend has a TMS car 70mm/.63 and is uncontrolable in the burnout box. Its either on or off,going to a .82.
I set up a car with a LT70 -P trim with the PTE .63 three bolt housing, worked great with a 9"AC. the car ran low 11's should have been a 10:90 car but I told him the 50# inj's were not enough for that combo.
He is talking about the turbine housing.... that fits the P Trim wheel... not the wheel itself.......There is alot of difference between exhaust housings..... IMHO
