OK, the FT site is back up and I will post the info here.
In the ini file, replace the section below, with the info listed.
Copy it EXACTLY as below, and replace it!
[CustomAnalog4]
CustomAnalog4Name=Fuel Pressure
CustomAnalog4LongName=Fuel Pressure Sensor
CustomAnalog4Tag=FP
CustomAnalog4GaugeMin=0
CustomAnalog4GaugeMax=100
CustomAnalog4GraphMin=0
CustomAnalog4GraphMax=100
CustomAnalog4MinValue=0
CustomAnalog4MaxValue=85.3
CustomAnalog4MinVolt=1.588
CustomAnalog4MaxVolt=5.0
After you replace the section, save the ini file, and launch the PL control.
Go to the "F3 Config and Download" page in PL, and under "Analog 4", pick the LAST option called "Fuel pressure".
DO NOT select the "Pressure 100 PSI"or "Pressure 100 PSI-B" option!.
This is for V1.4.0
That will work.
FWIW: My FP indicated 57 PSI before the update listed above, and now indicates 41. So, there is some adjustment, but 41 is realistic!
I would guess the 41 PSI is the result of higher voltage at the pump.
