Will t-link 4.0 with vehicle pak 6 work on my 87 Olds delta 88 with 3.8L? When I go to select a vehicle under 1987, Olds isn't listed. I assume I can load it as a Buick or Pontiac with vin#3 but want to make sure before doing so.
Also, just for the sake of feedback, I wanted to tell you that I traced a vacuum leak problem I had back to the T fitting and hoses that came with my boost harness. Hoses didn't fit tight and were leaking so my reading wasn't moving much under vac or boost, and did the same to my stock boost gauge. I unhooked the T and plugged the factory line straight to the 3 bar and it worked fine after that. I don't need the stock boost gauge anyway. Not mad or anything, I actually love it now that it works right, just thought you'd wanna know.
Your help is greatly appreciated.
bob
bob
