Painting rockford amps?
88 CuttyClassic
The Enviromental Hitman
I already did it, but is it ok to paint rockford amps? I have two black and grind amps with a punch link. I painted them to look exactly like my hurst olds (stripes and all) I must say they look sweet. I used engine enamel cause it could withstand the heat.
I also painted all my other rockford components to look like the car (two caps, fuse block, dist block). I'll post some pics when i get them.
No, i put the end caps on and the link on, then from the under side taped the seems and masked off the bottom. All the connections/controls are fine. I didn't paint anything that would effect the functionality of the parts, like the brass terminals and such.
:confused:
why wouldnt it be ok to paint an amp? rockford or whatever? most amps come painted from the factory, it's like a car, just do it right. As far as the engine enamel goes I really dont think it's needed, unless your amps are running way hot, which won't last long.
