Parasitic Drain
Slick84GN
Not sure if I'm in the right spot, but... Does anyone know the milliamp spec on parasitic at the battery positive post (stock '84 GN). I'm pulling about .38 milliamps and the battery keeps going dead real quick. Haven't had a chance to load test the battery yet to be sure it's good (even though its new). There is an alarm on the car and I suspect that may be the culprit. Thanks!
Welcome Pilgrim!!...
Don't know the parasitic drain. but you might try to remove the connectors or the bulbs from the underhood and trunk lights to see if they are staying on after the lids are closed. the courtesy lights under the dash are another culprit.:cool:
Thanks for the info. The underhood lamp is already removed. I'll check the truck and courtesy lamps to see what happens. Thanks.
