Part info needed for '86-'87 turbo Buicks
Randy Hagins
I am in the process of starting to buy parts for my next GN. I would like to get some info on the following , unless someone has them for sale.
Double roller timing chain: Where to get a good one. Last one I bought was from ATR and as most know, they are not in buisness anymore.
Trans. cooler kit : with hoses, clamps etc. Here again, the last kit I bought was from ATR....really stinks they are not around anymore.
Air conditioner hoses: I would like to get a new one that has never been used, if possible.
As always I appreciate the info/help.
Randy
http://www.cottonsperformance.com/proddetail.asp?prod=3129&cat=35
As far as I know but if you want to be positive call either Cotton's or Comp Cams.
T/A performance make a billet single roller that you can keep your stock tensioner with. With a double roller, you need to ditch the tensioner.
So I'm assuming with a double roller and without the tensioner you need to get a size length slightly smaller right, read that somewhere on here?
Anyone who sells the double roller should be able to sell you the right one, but I'm not aware or educated enough to know if the double is smaller. I use the double roller from Kirban with 50k miles now and there is still virtually no slack. I think I'm going back to the T/A one though with tensioner on the new motor.
