PARTING 87 GN and 86 T-TYPE+ BIGGER PARTS LIST
Intercooled88s
Moderator
New Parts added to list
8.5 Posi rearend Complete drum to drum with driveshaft $750
NOS set up for GN bottle, wiring, braided lines, 6 foggers nossles and solinoids $200
T-top metal trim plates that go under t-tops in good condition $50
GN Hood scoop(bump in center of hood , cut from a GN hood) $50
87 Stainless down pipe 2.5 , uses factory elbow $75
84 Hydrobooster brakes $100
87 GN grill $90
86 T-type Grill $50
86 Gray Lower concert sound door panels $100
87 Grand national lower door panels $60
GN dash Plaque $75
Grey console $150
Grand National console $150
Factory shifter(no T handle) $30
Grand National seats in good condition $500
Turbo crankshaft needs to be turned but will clean up at .010/.010 at worst $200
8445 heads pulled off a running engine, have new springs $40
Vacuum brake set up $65
84-87 T-type header panel $125
87 GN header panel $250
87 GN fenders $100 each
87 GN Front bucket seats need recovering $150
86-87 GN locking T-tops $150 a set
87 Blue lower Concert sound door panels $100
86-87 AC compressor $60
Misc.
BRF valvebody $200
GN rearend(8.5 non posi , drum to drum withdriveshaft ) $500
Driveshaft for 8.5 rearend $50
Transmission cross member $40
87 GN good running 109 short block $700
BQ coded GN transmission 48k $300
BRF tranny $500
Stock 200 4r tranny pan $30
86-87 GN wheels good for cores all 4 for $120
INTERIOR
Steering column(floor shift) $120
85-87 Gn Steering wheel(good to have recovered) $50
Plate on console that goes around the shifter $40
Grey rear sail panels(panels around the quarter windows) for t-top car in great condition
$40 for both
Grey Third brake light $25
85-87 GN seat belt set(10 pieces) $70
I have all the plastic interior pieces for a marroon or grey car with either t-tops or hard
top .
Nice grey arm rests $15 for both
Nice blue passenger visor with lighted mirror $25
Map light $20
Gauge surround $35
radio surround $25
Stock GN radio $50
Maroon dash pad $110
Blue dash pad $120
Grey dash pad $110
Light sage green arm rests(these are the rare light green color) $40 for both
Light sage green seat belt guides $25 for both
Light sage green seat belt upper bolt cover, triangular shaped trim piece $20 for both
T-TOP trim around the t-tops on the inside of the car in Red, Maroon, or grey , all 6
pieces
$100
ENGINE PARTS:
84-85 valvebody with TPS,IAC motor,vacuum manifold $50
stock 86 chip $30
stock 84 chip $20
86-87 Turbo $150
86-87 Turbo can be used as a core $75
84-87 Turbo elbow $25
86-87 MAF $80
85-85 ECM $40
86-87 ECM $70
Engine frame mounts $35
86-87 oil return to block, brass adapter,screws into block in front $20
86-87 Throttle bracket $35
Intercooler brackets both for $50
underdrive pulleys(crank and alt) $40
86-87 Crank pulley with adapter $30
86-87 dipstickand tube$40
86-87 Factory Oilfiller tube and cap $30
86-87 Scoop for airbreather $20
N/A crank std./std. $40
109 Block $300
crank $325
.020/.020 Turbo crank fresh from the machine shop $150
stock 8445 heads needing rebuild $40 a set
86-87 Lower intake manifold $130
84-85 GN intake $40
84-85 fuel rail $25
Any year injector harness $35
84-85 valve covers $35
86-87 valve covers $35
cam position sensor just the lower part(no cap) $30
86-87 MAF $100
84-85 MAF $45
84-85 AC compressor $40
84-85 Alt $35
84-85 turbo adaptor $25
84-85 crossover pipe $35
84-85 Alt $30
84-85 engine wire harness $100
86-87 engine wire harness $175
Any other harness on the car e mail I have them all
86-87 Power steering pump $60
86-87 AC compressor $70
86-87 Belt tensioner $70
86-87 Alt. $60
86-87 Main accessory Bracket $80
84-85 Main accessory Bracket $50
Small plastic guide that holds the posi bat cable to the lower front cover $20
84/85 to 86/87 conversion parts(all the original GN parts you need to convert over from 85
to 87) $1500
Oil cooler adaptor with nut $35
Timing cover $30
Turbo rods(2 dot) $40 a set of 6
Turbo flex plate $25
Turbo oil pans $35 each
84-85 control module $50
84-85 coil pack $40
Body & Misc.
mast for manual antenna $30
PowerMaster brakes assembly $200
GN rear bumper $100
Alum. rear bumper reinforcement $80
86 GN grill $90
85 GN grill $60
85-87 T-type grill emblem $20
84-87 GN fenders(GM) $80 each
Non Key locking t-top $90+shipping for the set
86-87 Locking t-tops+keys $200
T-top bags $35
Lock set(all 3 locks with key) $60
Drivers missor $20
Passenger remote mirror $40
Blackout door handles $25 for both
GN Spoiler(GM not after market) all 5 pieces $200
GN tail lights with blackout trim $100
Quarter glass with blackout trim $85
3 piece windshield blackout trim $30
3 piece rear window blackout trim$20
Black wheel well trim $40 each
Turbo plastic wheel wells $80 each
Any other blackout piece e mail me I have them all
GN hood $95-$150
AC lines $45
Turbo gas tank $40
GN sway bars $30 each
windshield wiper assembly $15
Complete heater box $100
E mail me at Fortune628@aol.com (best way to contact me) or PM
413 746 9668 (I rarely check voice mail)
More Parts For sale
87 GN radiator in great condition $100
84 GN radiator also in great condition $70
? on parts
what is included in---------->Vacuum brake set up $65 ?
would you sell the underdrive alt pulley by itself?
pm me back so we can workout a deal on this and the other stuff that i told you that i needed.
thx
buickbert
8445 heads pulled off a running engine, have new springs $40.
86/87 heads? Do you know what # springs? Also the 2.5 Dp ATR?
mcroz3
I think they are sold , was told a Money Order is on its way. I'll let you know once I get it, otherwise they are yours.
Air Con- Compressor
Do You Still Have The Aircon- Compressor? If So How Much To Ship To Ohio-43609? P.s. Do You Have Pics? Thank You. Frank.
mcponch
I'll check shipping a little later or in the morning. What E mail do you want the pictures sent to? thanks
Map light
Map light: sent e-mail for map light. $25/shipped to 78023? Let me know. E-mail your payment address, also. USPS money order OK? Thanks.
underdrive pulley set
does the crank pulley have the adapter to use the stock fan? thats really the only pulley i would like to have. made buy who?
I'll take the engine wiring harness for the 86-87 if it is complete and unmolested.
Mark
