***ANY QUESTIONS? EMAIL ME AT KERRYBURGOYNE@YAHOO.COM*** Parting out whole car. Its a 1987 Grand National Clone. All body parts are from a grand national as well as interior. I will sell every turbo buick part I have( steering colums,steering wheels, Digital dash and climate control, power master setup w/pedal, blocks,turbos,heads,crank, rods, forged trw pistons, F/G rear bumper, intercoolers, body mounts ETC., the car, title, any thing I own related to buick for 6000.00 FIRM or COMPLETE MOTOR, Trans, wiring harness(complete drop in running engine) for 5000.00 FIRM I am getting out of racing and want some spending money for my boat. I am also willing to trade some parts for any OFFSHORE FISHING TACKLE- such as Penn International reels, trolling gear, gaffs, etc. OR Will trade for anything I could use on my 35' Viking. If you are interested in any parts that I havent listed, email me at kerryburgoyne@yahoo.com. I will ship the parts that can be shipped via USPS anything else must be picked up in POINT PLEAQSANT NJ.
-engine- just rebuilt and have all pictures of process
Short Block-
fresh .030 turbo block with girdled mains, -
Crank- STD stroke 4340 forged steel balanced and clearanced( .0025 on mains and rods) cleveite race camphered main bearings and wide rod bearings
Rods- 4340 forged steel H beam rods, bronze bushed, dowel pins in cap, arp cap bolts.
Pistons- forged Wiseco full floating dished with plasmamoly rings -file fitted.
Oil pump- high volume, clearanced melling
1500.00 for complete short block( less than 500 miles on everything, Have recipts. )
comp 212 hyd. Flat tappet with brand new lifters- 75.00
Comp 1 pc moly pushrods. 50.00
Ported and polished Heads and intake- 800
ported and polished steel done by VPE ( have pics of port work, done super nice) Ss manley valves, new comp cams valve springs, port matched intake with power plate. FLOW 225/185 Real flow Numbers....
poston turbo 6 buick valve covers- 75.00
60lb motion injectors-150.00
billet accufab adj. Fuel pressure reg-50.00
255lph walbro with hot wire kit-100.00
progressive alky injection. -250.00
Induction-
precision front mount IC, 500
precision te66 turbo 700.00 3" stainless Tig welded custom down pipe with external wastegate 250.00,
800.00 for both or (1200.00 for Turbo, IC and DownPipe.)
3" exhaust with ATR pit bull ss muffler, test pipe. 150.00
Ignition- new cam sensor with caspers L.E.D adjustment cap, 75.00
new accel coil pack and new module 150.00
Electronics- scanmaster 2, 150.00
innovative wideband O2 LM-1 kit with summit gauge-, 125.00
MAF Translator with LS1 MAF- 150.00
autometer ultra light 2 boost gauge 40.00
5" autometer tach 50.00
Transmission- BOP th350 built with alto components, 3500 stall converter, aluminum deep pan, 750.00
quarter stick shifter w/ Grfand National console. 100.00
Suspension- ALL UMI
UMI 1978-1988 G-Body Adjustable Upper Control Arms- w/ Roto-Joint- 100.00
UMI 1978-1988 G-Body Boxed Lower Control Arms- Poly/Roto-Joint- 150.00
90/10 shocks in front- 50.00
1.5" solid rear sway bar. 75.00
Strong posi 3.42 gears. 750.00
Centerline 5 spoke(star) wheels with used ET Streets. 350.00
Short Block-
Induction-
Suspension- ALL UMI
