Dynotech motor je pistons 9:1 shot peened stock rods billet main caps 214 cam double roller chain stock heads less than 3200 miles and maybe 35 passes on motor. Dynotech hi-pro trans shifts perfect 32-3600 stall less than 3200 miles Precision pt67gts turbo less than 500 miles 72lb injectors computer with drivers. And an assortment of chips Goodyear eagle fronts and Mickey Thompson 295-55-15 rears like 5 passes on both on weld prostar xp rears. Front rims are summit stars. Reds double pumper in tank fuel pumps Smc dual nozzle alky kit Interior like new only a few small blems but overall great. Rear is stock with aluminum drums and aluminum Gn cover. Comes with mosier 28 spline axles and c clip eliminate Doors are clean no rust. 4 inch maf pipe Maf translator Atr front mount with blow off valve. Aluminum be cool radiator Kenne bell 70mm tb and plenum. With power plate Im sure there's a ton I'm forgetting still but that's what it is.
And whatever odds and ends you need
Text or call 7325017442 Jeff
Unless you want the whole car
