parting out.......87 modified GN
Where are you located?
I am Interested in possibly working a deal with the car...Including the shortblock-Heads-Turbo...And a few other items.
give me a call..732-778-2273 anytime...Sooner the better,I am looking at a few different rollers.
Thanks,Shawn
Dp
Still have the DP if so can you send pics. will it work with stock turbo and stock headers, very interested.. Thanks
i will be parting out:
all parts are in great or good condition
first off,the motor and drive train,ect
1987 buick GN:
PARTING OUT:
1987 BUICK “HEAVY MODDED” GRAND NATIONAL
REBUILT (8K) “109” SHORTBLOCK
WISECO FORGED PISTONS, J.E LIGHT WEIGHT PINS
TREATED RODS
TURNED CRANK 20’
ARP EQUIPPED
COMP 212/212 FLAT TAPPED CAM
COMP LIFTERS
BALANCE AND BLUE PRINTED BY FAERMAN RACING ENGINES/HOUSTON TX
GM TIMING COVER
RJC OIL BIGGIE ADAPTER
$1,850
Duttweiller iron stage III ported heads
Fresh and recently fluxed
100# comp springs
Larger valves
Gm stock rockers, RJC solid shaft
Flowed 240 cfm
Nice heads!!!!!!
$850
Stock buick lower intake/kenne bell upper polish plenum
Cleaned and in good condition
$250
Kenne bell polish 70mm throttle body
Good condition
$190
Kenne bell fuel regulator
Good working condition
With factory fuel rails
$150
Msd 50 lb injector
Recently cleaned and flowed
$200
Nick micale modified 3 core radiator
Recently flushed for leaks
Best radiator up to date,kept my car cool @ 175 all day!!
$275
Update 1/6/07
87 buick turbo factory headers
Good condition
Passenger header recently fixed for cracking
$120
Terry Houston 3 in down internal DP.
Good condition
$300
Conleys performance 3 in dual full exhaust
Good condition,no rust! 2 yr old
$280
Stock coil and module
1 yr old
Gm product
$100
Jacob race wires
8.5 mm
Like new
$30
Single electric fan
Worked great!
$50
CAS v4 stock location 23 row intercooler
Has small hit on the bottom
Does not leak however
Black
$230
Hoses and clamps
$25
200amp alternator with volt regulator
$250
Gm direct sterring pump and hoses :
Good condition
$100
Gm direct full working AC of the GN
Everything worked great
Needs to recharge due to unistalling off my car
Great for converting back to stock!!!
$380
Innovative t-70 BB turbo
No slack no play
Spooled was the best!!!
Ceramic coated
Arp bolted compressor
63/ exhaust housing
$950
Buick chrome turbo inlet tube
$40
Buick 3in Conley performance gloss black maf pipe
$40
Gm direct modified 3 in mass air meter
6 months old
$100
Buick log 6 tall valve covers
$140
Art carr 3200 NL 9 in. billet stall
1 yr old.
Great condition!
$550
Art carr built 200r4 tranny with red line internals
Right step transbrake
Bad ass tranny!!!
$1500
Gm direct driveshaft
Stock
$100
I assume you have flow sheets with those heads?
wheels
Are the wheels and tires in the pics available? Maybe I missed something, but it looks like you have a nice GN why are you parting it out???
Haven't hear anything back on the exhaust yet?? Is it still on the car?
Curious if it's a cat back system with the Converter flange?
Let me know, Pics would be great too.
Thanks again.
been lost for a few years now,since 97 bro.. but i have pics of the heads, and if you want i can bench tested for flowness by faerman racing engines,which he has the heads right now.
Thanks again.
i will pm you sorry brother, to many pms!
Soto,
What the steering wheel like on the car? Im interested if it's stock and in good shape. Im also interested in the front speaker cover if it's not cracked. I left you a voice mail on your phone.
Thanks,
Chris
Soto,
Thanks,
Chris
whats up chris, isorry i have not return your calls, been very busy and top of that my wife has not given me my charger back!:mad: and my cell has been off for quite some time.. the front speaker panel is crack on both ends! but the steering wheels looks good,id say 8 out of 10,. ill take pics. so you can check both the parts out. thanks
