WarWagon
Caustic Cacophony
- Mar 10, 2007
That's right, any even fire cam will fit that block. The stock camshaft for those turbo engines is ok, the stock cam from the '86 and later turbo engines is better, I use and like the 206/206 roller in my blowthru Buick. A 204/214 cam is biggest i'd suggest and fits heads with no work needed. I've used all of these camshafts and you really can't tell one from the other.Yes, "around here" is Finland in my case.
The rules are very different, and change even more when the body is changed from the car.
Adam, since all the 78- engines are even fire, I suppose the aftermarket cams sold for even fire buick will fit to the block ?
Leaving the decision of which will actually work as well. I was worried if there's some that will not even fit in.
Going blow throug with a blow through carb and the 87 intake with custom adapter has been the other option in my mind.
That would enable using the 87 turbo as well.
But what else would I actually need there ?
For low boost, is the stock fuel pump enough, or woudl I need an in-line pump to overcome the boost pressure ?
If an inline pump is needed, I assume a regulator for the fuel pressure as well.
I'm worried it might end up being pretty expensive way.
Staying a draw throught style turbo will be simplest and cheapest but least power and can use OE fuel pump too. Another drawback for the draw through is the turbo has to be a carbon seal style turbo to handle vacuum and air/ fuel mixture and these turbos have more drag or friction with a carbon seal. The moment you decide if you want to go blowthru the cost and complexity goes up along with power potential but now the intake manifold, turbo and carb selections are many. Only with a blowthru style would your fuel system need attention.
