parts for 1984-87
I just for you to call so you can explain more in detail of what brackets you're looking for, that is all. no problem,MY GOD BLESS YOU!
Well I explained the steering pump bracket a couple of times. It's the one that bolts to the front of the pump. But you said you have the pump, and I don't see that in the pics either.
The turbo mounting brackets. There's a small S-shaped one, that's actually visible in the pic, attached to the back of the intake manifold. Not visible is a long one, that sits along the passenger side of the manifold and cradles that end of the turbo. There's also a smaller piece that attaches to the long one.
The pic shows the turbo and the intake manifold. To take the turbo off the manifold, you had to deal with the mounting brackets. But the long one and the little one that attaches to it are nowhere to be seen.
I could post scans of the drawings in the parts catalog. I can't really explain things much better.
--Jim Howard
--Jim Howard
SORRY about the problem, but i will remove the other brackets and post pics.
there's another part i didn't know i had that is connected with a heat plant and heater pipe.
Pics are definitely helpful, the more the merrier. Like I said, I can post the drawings if that would be helpful.
--Jim Howard
--Jim Howard
i think i found the parts you looking for, i will post them up.
Any pics of those parts you thought you had found that I'm looking for?
--Jim Howard
1984-87 parts
sold intake and plenum,both regulator. still have plenum,throttle body,fuel pump,injector 009,fuel rails, etc.
