All parts were removed with about 20k.
All parts for sale are plus shipping.
AC/Heater Shield $15
Heater Hose assembly with Heater Control Valve $75
Cruise Control with bracket $50
Fuel Sending Unit. $75
EGR Control Solenoid with vacuum lines $35
Fuel Rail with Injector Harness $100
Rocker Arm Assembly with Shafts. $50
Stock Style Adjustable Fuel Pressure Regulator. $35
Stock Original Fuel Pressure Regulator. $25
Electric Fan. $75
Stock Plenum ported for 62mm throttle body. $75
Stock Throttle Body $50
Stock Turbo Inlet. $25
AC/Heat under dash ducting. $100
Stock Original Map sensor. $25
AC Delco Coil pack used at track for 6 passes. $25
Comp Cams Dbl roller timing set for roller cams. $35
Brand new Comp Cams Dbl roller replacement chain. $25
Chrome K&N breather. $10
Turbonetics Variable Boost Control Regulator. $35
Link to pictures. ImageShack Album - 22 images
Also have:
Stock Intercooler. $100
Stock Original Gas Tank. $75 (will not ship).
Original Transmission Linkage $35
Electric Fan. $75
Also have:
