PARTS GOING TO BPG
GM SUNROOF TAKEN OUT OF BURGUNDY INTERIOR CAR – NO WIRES CUT $450
BURGUNDY INTERIOR PIECES – UPPER AND LOWER DOOR PANELS WITH CONCERT SOUND WITH ARM RESTS AND 1 LIGHTED VISOR- UPPERS NOT SHOW QUALITY – $300
BURGUNDY SPEEDO PAD $75
DASH/SPEEDO BEZEL WITH OPENING FOR INTERIOR LIGHTS AND REAR DEFROSTER AND RADIO BEZEL TRIM PIECE $150
1 REAR BUMPER PAINTED WHITE $50
1 ALUMINUM BUMPER SUPPORT $150
STOCK FRONT SWAY BAR $50
1 PAIR BRAND NEW PPG WINDOW GLASS FOR 87 REGAL $125
9 HOLE HOOD PAD ORIGINAL – USABLE – NOT PERFECT NOS $235
SNAP ON MT 402 ALT/GEN/REG TESTER BRAND NEW NEVER USED $45
1 MOROSO ROUND TRANS COOLER $20
FEL PRO HEAD BOLT SET ES74022 $25
ATR CANISTER RELOCATION BRACKET $25
SUMMIT 0-8000 3” TACH $30
TWO SMALLER PERMACOOL 12VOLT FANS $20 A PIECE
SEVEN GM BUSHING – NEW $5 APIECE
PERFORMANCE FUEL SYSTEM ON RAIL FUEL GAUGE $20
STOCK CRANK – NEEDS TO BE CUT $150
ONE PAIR GN SPOILER END CAPS SMALL CHIP ON INSIDE LIP $75
PLX M-300 AIR/FUEL RATIO $175
THREE FUEL PUMP HANGARS SOLD AS IS $35 A PIECE
THREE TRANSMISSION DETENT CABLE BRACKETS $75 EACH
ONE POWER ANTENNA REPLACEMENT INSERT $75
TWO TIMING COVERS - $100 A PIECE
USED FUEL LINES TO RAIL $25
BLUE GLOVE BOX $15
14 STOCK INJECTORS $25
1 SET USED DIRECTIONAL TURN SIGNALS OFF GARAGE KEPT 61K LIMITED $50
2 SETS OF USED DIRECTIONAL TURN SIGNALS $40 FOR ALL FOUR
6 STOCK FUEL PRESSURE REGULATORS $10 EACH
CHROME FP REGULATOR COVER $15
ONE T-TYPE RIM $75
3 IC SCREENS $10 A PIECE
1 MINI STARTERS $45
GRAND NATIONAL EMBLEM SET (ALL 5) – GOOD SHAPE $150
5 STOCK HEADLIGHT TRIM BEZELS $50 FOR ALL
TRANS CABLE TO SPEEDO $50
OIL LINE/FILTER ADAPTER $40
2 CAM SENSORS $150 A PIECE
3” STAINLESS STEEL CATALYTIC CONVERTER - $150
5 SETS OF OUT OF DATE RACE HARNESS’ 3 RCI’S AND 2 SIMPSONS - $30 A PIECE
THREE OIL DRAIN BACK PIPES TO BLOCK $50 A PIECE
ONE OIL DIPSTICK COMPLETE - $55
ONE OIL DIPSTICK ONLY – NEEDS TO BE GLUED - $20
TWO TRANSMISSION DIPSTICK TUBES COMPLETE - $40 A PIECE
AUTOMETER PRO SHIFT LITE $45
SET OF DELPHI LUCAS 42# INJECTORS - $125
SET OF COMPETITION ENGINEERING DRAG SHOCKS- 50/50 AND 90/10 – USED $50
GAS TANK METAL STRAPS - $35
2” AUTOMETER VACUUM GAUGE $25
2 BUICK GRILL EMBLEMS $15 A PIECE
PULLEY FAN PAINTED BLACK $25
UNDER HEADER PANEL BRACKET $25
BALANCER PULLEY RING $25
1 SET CHROME DIRECTIONAL BRACKETS $25
STOCK TURBO INLET BELL $25
AC COMPRESSPOR/HEADER BRACKET $50
DOME LENS $10
USED IAC $15
1 USED AC LINE SHORT ONE $25
AUTOMETER TACH HOLDER $20
1 SET CRANE 8MM WIRES $35
I REAR BUMPER IMPACT STRIP TAKEN OFF 61K GARAGED LIMITED $75
BIG TUB OF MISC INTERIOR TRIM PIECES - $75 FOR WHOLE BIN AND TAKE BIN WITH YOU IF COMING TO BPG.
ALSO BRINGING A LOT OF SMALL $5 AND $10 PARTS…..TOO MUCH TO LIST HERE.
LARGER ITEMS LOCAL PICK UP ONLY OR CAN BRING TO NORWALK IF YOU WANT THEM
ALL PARTS SOLD AS IS – NO WARRANTIES EXPRESSED OR IMPLIED
ALL PRICES DO NOT INCLUDE SHIPPING OR PAYPAL FEES.
BLUE GLOVE BOX $15
ONE T-TYPE RIM $75
1 MINI STARTERS $45
DOME LENS $10
USED IAC $15
