Will be taking the below to BPG, if you want something reserved PM me so we can meet up out there.
1 PAIR BRAND NEW PPG WINDOW GLASS FOR 87 REGAL $125
9 HOLE HOOD PAD ORIGINAL – USEABLE – NOT PERFECT $150
SNAP ON MT 418 PRIMARY TACH DWELL MACHINE BRAND NEW NEVER USED $45
SNAP ON MT 402 ALT/GEN/REG TESTER BRAND NEW NEVER USED $45
MOROSO ROUND TRANS COOLER $20
GENERIC USED TRANS COOLER $15
FEL PRO HEAD BOLT SET ES74022 $25
ATR CANISTER RELOCATION BRACKET $25
ONE STOCK CAM USED - $20
ONE POWER STEERING DELETE PULLEY $45
TWO SMALLER PERMACOOL 12VOLT FANS $20 A PIECE
AUTOMETER 2 INCH TACH 0-8000 $25
SEVEN GM BUSHING – NEW $5 APIECE
PERFORMANCE FUEL SYSTEM ON RAIL FUEL GAUGE $20
STOCK DOGHOUSE PAINTED BLACK $45
STOCK CRANK – NEEDS TO BE CUT $150
ONE PAIR GN SPOILER END CAPS $100
PLX M-300 AIR/FUEL RATIO $175
THREE FUEL PUMP HANGARS SOLD AS IS $35 A PIECE
THREE TRANSMISSION DETENT CABLE BRACKETS $75 EACH
ONE POWER ANTENNA REPLACEMENT INSERT $75
ONE POWER ANTENNA ASSEMBLY-STUCK IN UP POSITION $20
DRIVER SIDE INNER FENDERWELL TURBO APPLICATION $100
PASSENGER SIDE FENDERWELL NON TURBO APPLICATION – NEW NEVER INSTALLED $40
AFTERMARKET TURBONETIC TURBO SHIELD $25
TWO WATER PUMP PULLYS $15 EACH
TWO TIMING COVERS - $125 A PIECE
USED FUEL LINES TO RAIL $25
BLUE GLOVE BOX $15
14 STOCK INJECTORS $25
2 SETS OF USED DIRECTIONAL TURN SIGNALS $40 FOR ALL FOUR
5 STOCK FUEL PRESSURE REGULATORS $10 EACH
CASPERS VDO CONVERSION TACH MODULE #102007 NEVER USED $25
USED STOCK MAF HOSE $20
CHROME FP REGULATOR COVER $15
ONE T-TYPE RIM $75
KIRBAN TOUCH AND GO ANTI THEFT SYSTEM-NO INSTRUCTIONS $15
4 IC SCREENS $10 A PIECE
2 MINI STARTERS $45 A PIECE
COIL PACK BRACKET $25
GRAND NATIONAL EMBLEM SET (ALL 5) – GOOD SHAPE $150
ASHTRAY 5 SWITCH PANEL $35
VDO 2 1/16 OIL PRESSURE GAUGE –MECHANICAL-NEVER OPENED $25
8 STOCK HEADLIGHT TRIM BEZELS $50 FOR ALL
BOTTOM OF STOCK AIR FILTER BOX $25
TRANS CABLE TO SPEEDO $50
OIL LINE SET UP TO RADIATOR WITH OIL FILTER ADAPTOR $50
OIL LINE/FILTERADAPTER $40
LARGE IC BRACKET $50
STEEL FRONT BUMPER INSERT $25
2 CAM SENSORS $90 A PIECE
3” STAINLESS STEEL CATALYTIC CONVERTOR - $150
5 SETS OF OUT OF DATE RACE HARNESS’ 3 RCI’S AND 2 SIMPSONS - $30 A PIECE
THREE OIL DRAIN BACK PIPES TO BLOCK $50 A PIECE
ONE OIL DIPSTICK COMPLETE - $55
ONE OIL DIPSTICK ONLY – NEEDS TO BE GLUED - $20
THREE TRANSMISSION DIPSTICK TUBES COMPLETE - $40 A PIECE
AUTOMETER PRO SHIFT LITE $45
SET OF DELPHI LUCAS 42# INJECTORS - $150
FRONT FRAME BRACES-FRESHLY PAINTED- NEED NEW SELF TAPPING BOLTS $35
87 GRILL – CUT FOR FRONT MOUNT/RACE CAR – NOT A SHOW CAR GRILL $50
SET OF COMPETITION ENGINEERING DRAG SHOCKS- 50/50 AND 90/10 – USED $50
GAS TANK METAL STRAPS - $35
2” AUTOMETER VACUUM GAUGE $25
BUICK GRILL EMBLEM $15
EFI FP RAIL GAUGE – NEVER USED $30
BACK OF ALTERNATOR “Y” BRACKET $45
“L” BRACKET BACK OF ACC/AC PLATE TO HEADER BOLT $25
BIG TUB OF MISC INTERIOR TRIM PIECES - $75 FOR WHOLE BIN AND TAKE BIN WITH YOU IF COMING TO BPG.
ALSO BRINGING A LOT OF SMALL $5 AND $10 PARTS…..TOO MUCH TO LIST HERE.
ALL PRICES DO NOT INCLUDE SHIPPING OR PAYPAL FEES.
BLUE GLOVE BOX $15
ONE T-TYPE RIM $75
