Parts I can deliver to BG
re-evaluating
Can't even re-member
Parts I can bring to BG I will ship the small stuff .
FAST sequential set up for distributor and IPU with individual cylinder correction, includes Caspers stand alone engine harness, wide band O2, and external data logger. $1000
Brand new Pat's converter for 76 turbo never had oil in it $650 $900 new.
New Weldon 2025A fuel pump (been installed but not run) $650
8 Bosch 142 lb Injectors part #280-412-912 used flowed by Richard Clark $350 shipped
3 1/2 in external downpipe for 3 bolt turbo $450
Raw Terry Houston pipe to make your own 3 1/2" downpipe $325
SX fuel pump, and regulator $225 shipped
Stock style rail adjustable fuel regulator $60 shipped
3 inch aluminum drive shaft for TH400 & 9" $275 shipped
Koni Spa 1 front drag shocks $100
Koni Spa 1 rear drag shocks $100
HRpartNstuff complete suspension package with adjustable uppers brand new with XD delrin bushings (trailing arms were installed but never left garage) anti roll bar is for 9” rear.
Used adjustable uppers trailing arm with XD delrin bushings
Used lower trailing arms with XD delrin bushings
daveunderpressure at gmail dot com
thanks
WANTED
REAR FIBERGLASS FILLERS 1 piece preferred.
Aluminum 9” center section 31 spline with 3.00 or 3.25 gear
Front end/fender cover
Shocks have 35 to 40 passes on them very low street miles. As you can see they are very nice shape with the exception of a little black over spray on the rears from a frame notch. I have been mid 1.3 sixty foot times with them.
I don't remember. Here are a couple pictures.
The first one was built in pieces and has an ugly weld as you can see, but it is low enough it isn't seen on the car.
COULD I GET PICS OF THE TWO DOWN PIPES
THANKS
As I said in the above post I don't at this time. I don't think there is anything you could see in a picture. They are in new condition with the exception that the bushing are lubed and installed. It is obvious that the bolts have been put in show signs of grease and a socket was on them. The sway bar is still in the plastic and bracketing is still wrapped.
Do you have any pics of the trailing arms?
I miss understood, I thought they were seperate from the other parts. I have the factory 8.5
Sorry I must have misunderstood on my end. I will try and get pictures of the used set tomorrow. You are correct, I have a new complete set up and a used set of upper and lowers.
Hey John I can do that for you old friend. PM me your zip code I will see if I can get a shipping quote for you. I may not be able to get it shipped before I leave for BG if thats ok.
I'd like the raw dp if you would consider shipping it.
the lowers have some over spray on them would probably come off if you tried.
Can you pm me a price with shipping to 61520. As of right now I am not 100% if I am going to bg or not
Thanks Jay
