Do some searching in the suspension section and get an idea of what others have done and whether they like how things work. Like Aj said, you're not trying to burn the track up so you really don't need bigger brakes. I'm not a fan of drilled rotors because they can crack due to heat, but if you're not really trying to do much more than cruise then they should be fine.
