conn84gn
- Jul 13, 2005
Well being off for the holidays figured I had time to set her up to go through emissions.
Took off the THDP and Y pipe and replaced it with stock elbow, downpipe and new high flow 2.5" cat.
Turned down the boost,fuel pressure to 38 PSI turned off the ALKY
Put in the emissions chip from Eric, turned the translator back to zero
Ran it about 10 mile and went for the test (still on 009s)
Here are the numbers:
HC (PPM) Limit 132 Tested 66
CO (%) Limit 0.42 Tested 0.06
NOx (PPM) Limit 921 Tested 192
