Passenger side header removal.......
irockwithdirt
Senior Member
Too disgusted to even go look at the car right now but will prolly wrench on it for a few tomorrow. What is my easiest way to remove the pass header? Pull the inner fender? What should I be ready for? Maybe I should just pull both and check for cracks (would have been nice to get the up pipe on and see if I had any other leaks........ f#*kin car!!). Thanks for any input, Kevin
you will need to do the following:
remove alternator, unbolt a/c compressor from bracket, a/c bracket, up pipe, crossover pipe.
