PCM location ??
aquickv6
How does the PCM mount in the original airbox? 2000 GTP
Removing the K&N and returning to stock.
Also How do you re-install the rear view mirror, there is no set screw. Center palte off, center plate on? Must be a trick.
From what i rememeber the PCM in my 98 was just laying in there with no real way of being secured.
what kind of car....the PCM fits in the bottom of the stock air box in a compartment. as for the rearview mirror....it depends on the car i beleive ....neil's regal gs (8uwith6) the rear view mirror is stuck on by adhesive...mine is attached to a bar that goes under the headliner.
