vacuum 6
- Jan 6, 2006
To help with blow-by I've come up with a PCV BOV. Instead of running a evac to the breathers its run to the PCV. In vacuum it works just like a normal PCV system however in boost the check valve cracks at .3 psi then fully opens at 4 psi (pump turns on).
Looking at the picture the bottom port in placed into intake. The upper port goes to vacuum with a rubber hose between it and the PCV. The barb goes to the pump.
