Pegged out Fuel Gauge?
WhiskeyGN
My fuel gauge is pegged out past full (doesn't matter how much gas) Anyone have this same problem? Is it the float, gauge or a ground?
Could be a bad sender (in tank), gauge (in dash) or the wire (gray IIRC). If you have a spare sender lying around you can disconnect the pigtail at the bumper and plug the sender in and see if does the same thing.
Ground the wire going to the gauge. The gauge should read empty. If it does, the problem is the sending unit or bad ground at the tank. If it doesn't you could have a bad connection at the dash.
Where do I do that (which wire do I ground)? I just took the cluster out and put the needle at 1/2, plugged it back in and it pegged out.
I am watching this thread I am having same issue. I am planning on dropping my aftermarket tank and just start grounding the unit, ground wire whatever to see if it will work.
I detached the pigtail and the tank and connected them thru 2 diff. wires but grounded the black one thru another wire to the frame and the gauge went to empty. So where is the tank ground at?
The tank ground is supplied by the pump ground...all is common on tank/sender....if memory serves me right...
I figured it out, the sending unit is effed. My rusty spare worked just fine so off for a new sending unit tomorrow.
Thanks for posting up your solution...it will help future searchers.
I found out it was the little board that the float contacts with the thin wire wrapped around it held on by those two screws was bad. Someone prolly knows the name. I just swapped that from an 88 cutlass and it works fine.
Read this post wrong, i thought they ment a "fuel rail" gauge...
The Dashboard fuel gauge what's this thread's about.
While back,Mine use to stick at 1/2 tank,If i hit the dash,it'd go back to reading right.
was the gauge it's self that was shorted
Enjoy!
