Performance 109 engine for sale!
Nick Micale
Tech Advisor
Staff member
For all the "heat" I took on the alum engine for sale with no pics or price, this time you will have both, plus lots of specs. :biggrin:
I have been putting together this engine for a customer, and when he was aware of the alum build, he decided on that one, and is now selling his 109 block/engine. :)
This build has the following:
2 steel center caps
Eagle forged crank and rods
CP pistons w/HD pins and Total Seal file fit rings
TA SI ported heads, roller rockers, valve covers
New turbo timing cover and pump from TA
Billet cam with solid roller lifters
Rollmaster chain set
SFI balancer & flexplate
Stock oil pan
No intake is included.
So far his cost is over $9500, but is willing to sell it for $8300.
Additional information can be had by phone or e-mail, PM's usually take longer to answer as I do not have a computer in my pocket like many of you do! :wink:
Are the heads 14 bolt? If they are would he consider just selling the heads if someone wanted just the short block? Thanks!
If we can come to terms on the heads and short block with you both, I have a home for the cam kit.
All TA heads are 14 bolt.
The crank is a stock stroke.
I will check with the owner tomorrow on separating these parts, and if you guys are serious, I will try to make it happen.
It will probably require a dialog and personal conversation with each of you to put it together, thanks.
First, another comment about this build, all the parts are NEW, except the block, and have 0 run time. :)
You three guys that want the short block, heads and cam kit need to contact me by phone or direct e-mail to discuss details exactly what you want to purchase, and then, hopefully, we can arrive at a final cost.
I also have a back-up deal on the heads, if turboclam3 decides to pass, so the short block will be available.
Oh, the springs are for a solid roller so they should stay with the cam kit, and I can install proper the springs for the final use, or leave those and supply other springs with the cam kit.
The cam and heads have been sold, so the short block is now available.
The cost to build this short block with all new parts and a good 109 block is over $6000. The owner wanted to be firm on that price, but persuaded him to discount $500 for a quicker sale so he, and I, can move on. :cool:
I can still add a cam and heads for a complete engine if someone would is wanting a complete long block assembly. :smile:
