Performance Parts
hemi8
Goin Sideways
TurboBuick.com Mini Starter, excellent condition, 70.00 SOLD
AC Delco 120 amp alternator (bought new, only has 8k miles) 90.00 SOLD
Power Bastards 240 amp Super Alternator : http://www.powerbastards.com/products.asp?cat=18
250.00 SOLD
Champion Racing A/C delete mounting bracket, keeps P/S & alternator, complete with ALL proper hardware
190.00 SOLD
Stock crank pulley, 30.00
Rebuilt P/S pump w/pulley, 75.00
Belt tensioner, complete, pulley replaced approx. 4k miles ago, perfect condition 150.00
Innovate Wide Band O2, complete setup ready to drop in, works with Turbo Tweak WB tracking chip, no scratches, perfect condition. 150.00
Excellent Condition factory glovebox, restored using G-body proper grey paint 50.00
New Accel coil pack 70.00
Stage 2 wide journal On-center Carrillo rods, 6.5" length, excellent condition, 350.00
All items + shipping, PayPal is fine.
Mike
I'm not sure if the length is the same, so I will include the proper bolts.
Mike
Few more parts:
- 3 3/8" Electronic Speedo, programmable, built-in turn signal and high beam indicators, SpeedHut Revolution series, in-dash mount, backlit blue at night. 140.00
- Mini 2 1/16" SpeedHut Revolution series matches speedo, comes with shift light, backlit blue at night. 100.00
- Caspers knock gauge, 60.00
- Stage 2 water outlet, 40.00
- Custom gauge panel, made to bolt to the small gauge bracket made by GNS. 45.00
- New TRZ manual brake master cylinder mounting bracket, 100.00
- New AC Delco electric vacuum pump w/Racetronics wire harness, pulls the crankcase gases out of crankcase, turns on by Hobbs switch at 3psi boost (included) 200.00
+ shippingDSCF0231.JPG DSCF0233.JPG DSCF0238.JPG DSCF0244.JPG DSCF0248.JPG DSCF0249.JPG DSCF0253.JPG DSCF0268.JPG DSCF0272.JPG DSCF0274.JPG , Paypal is fine.
Mike
Few more parts:
+ shippingView attachment 263212 View attachment 263213 View attachment 263214 View attachment 263215 View attachment 263216 View attachment 263217 View attachment 263218 View attachment 263219 View attachment 263220 View attachment 263221 , Paypal is fine.
Mike
And a few more, cleaning out all my excess gear:
- Elite PVC catch can, I had this bolted to the turbo S bracket, comes with hoses and GM PCV. See it here:
http://www.corvettemods.com/Corvett...h-Cans--LS1-LS2-LS3-LS6-LS7-97-13_p_6615.html
110.00
- Stock intercooler fan w/bolts, 40.00
- TR Customs radiator overflow tank, 70.00
- GMB high flow, high performance water pump, bought from Summit Racing, it is a GMB part# 130-1070P. 60.00
- Comp Cams Pro cylinder head CC kit, 100cc, complete part#4974. 80.00
- Aux. fuse panel. 35.00
- Oil filter adapter with Kirban replacement oil cooler hoses: 75.00
- Turbo oil drain, GM replacement. 35.00
- Kirban replacement fuel return line. 40.00
- Champion Racing Heads push rods (came with aluminum heads for use with Scorpion rockers on 109 block) 8.830, 0.65 wall, 5/16". 65.00
- Trend push rods, 8.350", 0.80 wall, 5/16, part# T835805. 65.00
- Comp hyd. roller lifter part#853-12 (Qty. 5) one went bad on me, instead of buying a new one I bought a set of TA's. These 5 are good. 120.00
+ ship
Mike
#3781, XD-16 Standalone, Gauge Kit w/LC-1
Yes, still available.
Mike
