UPDATED LIST
Will make a great deal for someone interested in everything, just message me amd we can work something out!!!
STOCK
Stock Trans Crossmember - Used good shape - $100
Stock passenger fender - Sanded down, very light surface rust, front bolt area damaged - $100
Stock GN Hood - Stripped down but does have some minor dents - $250
Both upper door panels - Roll up windows, Blue, slightly faded - $30
Trunk Weatherstripping - Good just dirty - $15
2 cluster supports - Some Broken Tabs - $30 each
T-top visor trim plastic - New from classic industries, Kirban Paint, holes opened up - $100
Passenger Door Weatherstripping - Still Soft - $15
Pair of Hood Hinges - Used good shape - $40
Passenger hood hinge W/Spring - Used good shape - $15
Complete set of door hinges W/Bolts - Used good shape, slight surface rust - $75
Both Horns - Used, Dirty - $20
Chrome weather stripping holder - Really nice - $20
Rear hood trim - Nice, nick from wipers - $20
Alternator - Damaged housing - $60
Condenser - Good shape - $25
HVAC Controller - Excellent Shape - $20
HVAC/Radio Surround - Nice - $20
Under Dash cover - Good shape - $15
Seat Belt W/Retractor - Good/Dirty - $20
Seat belt guide - Good Shape - $10
Broken Dipstick - Was going to make billet handle - $10
Flexplate - Good shape - $30
Passenger Mirror - Good shape - $20
Trunk lid bolts - Used - $5
Steering column support - Used - $15
Stock downpipe elbow - Used - $30
4 Bumper Bracket - Good Shape - $10 each
Booster support bracket - Nice - $15
Hood struts - Good used - $25
EGR W/hold down - Used - $10
Valve cover breather - Used - $10
Oil fill tube - Used - $10
Driver door handle - Really good shape - $10
Turn signal cover - Chrome painted black - $50
Complete HVAC ducts - Good Shape - $50
GN Steering wheel - Really nice, not perfect - $175
Dash electronic modules w/screws - Good - $20
Quarter extensions - Very good - $35
Center console - Rough top, good base - $30
Power Seat Controller - Nice, no cuts - $20
Stay down license plate - Nice - $20
Grill springs - 1 new, 1 used - $15
Under column cover/vent - Good, dirty, broken tab - $20
Door panel chrome strips - Was going to add carbon inserts - $30
Trunk release motor W/plug - Good - $30
Vacuum line - Good - $5
Hood strut bracket W/Bolts - Blasted and primed - $10
Fender to body support - Blasted and primed - $5
2 Chin Spoiler - Use with front mount, good shape - $15 each
Power Antenna - Used, assuming no good - $10
Rear seat bottom - Used, small tear - $50
Headlight Harness - Cut wires at each headlight - $20
Tail Light Harness - Good shape, No cuts - $20
E-Brake Release - Good Shape - $10
E-Brake Mechanism - Good - $20
Bracket - Used - $5
“T” Emblem - Nice - $5
Rear view mirror - Nice - $20
Turbo Shield - Uncut, dirty - $20
Mirror adjuster cover - Dirty - $5
Converter dust shield - Dirty, cracked - $10
Door buzzer arm - Nice - $5
“Limited” emblem - Nice - $5
Turbo oil feed - Used - $10
HVAC Controller Diaphragm - Good, New - $5
Regal Vacuum Ball - Good - $5
HVAC Vac lines - Good, 1 cut - $5
Driver remote mirror - Used, scratched - $20
Regal grill - Professionally Painted - $200
Hood bracket - Used - $5
Hot Air MAF - Used - $15
Grill Backing - Used - $10
Passenger turn signal housing - Broken, still usable - $10
2 Bumper frame - Blasted and primed - $15 each
Header panel support - Blasted and primed - $20
Stock fuel line - Used - $10
Rad overflow bottle - Used - $10
Computer kick panel - Used, some holes - $10
Cluster - Stock - $75
2 Washer bottle W/lid - Used - $10 Each
Mirror control base - Used - $5
Door switch support - Used - $5
Pass marker light - Used - $35
Vacuum “T” - Good - $2
Shifter Cover - Good - $10
Pass Mirror - Good - $10
Intercooler bracket - Good - $25
Shifter - Needs spring - $20
Crank pulley - Good - $40
Alternator - Good - $60
Intercooler Bracket - Good - $25
Hood Latch - Good - $5
Door lock W/Keys - Good - $15
Bumper cushions - Good - $15
Chrome door handles - Good - $20
Intercooler Fan - Good - $40
Stock Injectors - Good - $20
E-Brake Cable - Good - $10
Radiator Support Bracket - Good - $10
Stock sway bar - Good - $25
Water pump pulley W/Bolts - Good - $25
2 Sill Plates - Good - $20 Each
Stock FPR - Good - $15
Inner window sweeps - Driver used, Pass New
Bumper Strips - Good - $40
GN Upper door panels - Used - $30
2 Front Chrome Bumpers - Used - $75
Rear Chrome Bumper - Used - $75
Steel Bumper Supports - Used - $20
Coated Turbo Shield - Nice - $60
Stock Heads - Good, untouched - $100
Regal dash wiring harness - Some splices - $25
Regal engine harness - Some cuts - $20
Both GN Fenders - Trimmed for larger tires - $200
Stock upper trailing arms - Used - $20
Radiator - Used, still good - $50
Condenser - Used, still good - $30
Oil Dip Stick - Used - $35
GN Door Panel - Used, Faded - $40
AFTERMARKET
Aftermarket sway bar - Used good shape, dirty - $100
Chevy SSII Rims - Used - $50
Electric Fan - Good used spare - $50
Innovate wideband W/Controller - Good shape - $150
Kirban Lug Nuts - Used - $50
2 Hood to fender bumper - New - $4 each
2 Hood to rad support bumper - New - $5 each
Rear hood to cowl bumper - New - $6
2 Hood to rear fender bumper - New - $4 each
Door pull screw covers - New - $18
Turn signal screw set - New - $3
Kirban rear seat frame brace - New/scuffed - $50
Dashmat - New - $20
RJS racing belts - 1 set, 1 lap belt - $15
Kirban magnetic drain plug - New - $10
4” Exhaust - Used - $275
Autometer Tach - Good shape, long leads - $20
Complete "bolt-in" fuel system - Really good shape - $1000
Front Plate Bracket - Good shape - $20
Rear plate Bracket - Good shape - $20
Wiper electrical/Vac Line - No cuts - $15
Hood Hinge Bracket - Used - $5
2 Open Stainless Bolt Kits - Some open, some sealed - $30
Rear coil springs - Slightly used - $30
Test Pipe - Slightly used - $25
Turbo Oil Drain Gasket (7) - New - $15
GNX style center caps - Busted, 1 good - $5
Boost controller W/Bracket - Plastic - $20
Boost controller - Metal - $20
High Volume Oil Pump Kit - New, K20IHV - $40
3” Downpipe, Ext WG, Ext Dump - Used, 2 Dents - $350
FREE
Bumper Cushion - Shipping
Bumper Bolts - Shipping
Engine fuel line- End cut off - Shipping
T-Top lock covers - Chipped ends - Shipping
Door Insulation - Shipping
Driver headlight surrounds - Shipping
Seat Plug - Cut wires - Shipping
3 Door Sill Rubber - Shipping
2 Tail light plugs - Shipping
Cat converter Bracket - Shipping
Intercooler Shroud - Shipping
Bracket above rear - Shipping
Boxes of nuts/bolts/brackets/parts...If you need something specific send me a picture so i can match it and ill see what I have.
