Tons of leftover parts, Stock and aftermarket, all of it needs to go!!
oldsracer
Identity Crisis
I sold my car a couple months ago and its time for all the leftover parts to go. I'm looking to package deal everything I have for a week or two and if it doesn't all go by then I will break everything up and sell individual parts. All prices are plus shipping and if you buy something for asking price and need a part under the "free" area or random nuts/bolts I can throw it in you box and its yours. Adding it all up its about $7300, I'll let everything go for $3500 and we can work something out with shipping everything. Below is the list of what I have and I'm sure i missed parts but you'll get every GN part I have. Let me know if you have any questions.
STOCK
Stock Trans Crossmember - Used good shape - $100
Stock passenger fender - Sanded down, very light surface rust, front bolt area damaged - $100
Stock GN Hood - Stripped down but does have some minor dents - $250
Both upper door panels - Roll up windows, Blue, slightly faded - $30
Trunk Weatherstripping - Good just dirty - $15
2 cluster supports - Some Broken Tabs - $30 each
T-top visor trim plastic - New from classic industries, Kirban Paint, holes opened up - $100
Passenger Door Weatherstripping - Still Soft - $15
Pair of Hood Hinges - Used good shape - $40
Passenger hood hinge W/Spring - Used good shape - $15
Complete set of door hinges W/Bolts - Used good shape, slight surface rust - $75
Used trans mount - Used - $10
Both Horns - Used, Dirty - $20
Stock intercooler W/Shroud - Used, Shroud very rough - $50
Chrome weather stripping holder - Really nice - $20
Rear hood trim - Nice, nick from wipers - $20
Stock Downpipe - Good Shape - $20
Alternator - Damaged housing - $60
Condenser - Good shape - $25
HVAC Controller - Excellent Shape - $20
HVAC/Radio Surround - Nice - $20
Under Dash cover - Good shape - $15
Seat Belt W/Retractor - Good/Dirty - $20
Seat belt guide - Good Shape - $10
Broken Dipstick - Was going to make billet handle - $10
Flexplate - Good shape - $30
Passenger Mirror - Good shape - $20
Trunk lid bolts - Used - $5
Steering column support - Used - $15
Stock downpipe elbow - Used - $30
4 Bumper Bracket - Good Shape - $10 each
Booster support bracket - Nice - $15
Hood struts - Good used - $25
EGR W/hold down - Used - $10
Valve cover breather - Used - $10
Oil fill tube - Used - $10
Driver door handle - Really good shape - $10
Turn signal cover - Chrome painted black - $50
Complete HVAC ducts - Good Shape - $50
GN Steering wheel - Really nice, not perfect - $175
Dash electronic modules w/screws - Good - $20
Quarter extensions - Very good - $35
Center console - Rough top, good base - $30
Power Seat Controller - Nice, no cuts - $20
Stay down license plate - Nice - $20
Grill springs - 1 new, 1 used - $15
Under column cover/vent - Good, dirty, broken tab - $20
Up pipe - Good, dirty, used - $25
Door panel chrome strips - Was going to add carbon inserts - $30
Trunk release motor W/plug - Good - $30
Vacuum line - Good - $5
Hood strut bracket W/Bolts - Blasted and primed - $10
Fender to body support - Blasted and primed - $5
2 Chin Spoiler - Use with front mount, good shape - $15 each
Power Antenna - Used, assuming no good - $10
Rear seat bottom - Used, small tear - $50
Headlight Harness - Cut wires at each headlight - $20
Tail Light Harness - Good shape, No cuts - $20
E-Brake Release - Good Shape - $10
E-Brake Mechanism - Good - $20
Bracket - Used - $5
“T” Emblem - Nice - $5
Rear view mirror - Nice - $20
Turbo Shield - Uncut, dirty - $20
Mirror adjuster cover - Dirty - $5
Radiator Cover - Nice, original - $40
Converter dust shield - Dirty, cracked - $10
Door buzzer arm - Nice - $5
“Limited” emblem - Nice - $5
Turbo oil feed - Used - $10
HVAC Controller Diaphragm - Good, New - $5
Regal Vacuum Ball - Good - $5
HVAC Vac lines - Good, 1 cut - $5
Driver remote mirror - Used, scratched - $20
Regal grill - Professionally Painted - $200
Hood bracket - Used - $5
Hot Air MAF - Used - $15
Grill Backing - Used - $10
Passenger turn signal housing - Broken, still usable - $10
2 Bumper frame - Blasted and primed - $15 each
Upper rad hose - Used - $5
Lower rad hose - Used - $5
Header panel support - Blasted and primed - $20
Stock fuel line - Used - $10
Rad overflow bottle - Used - $10
Computer kick panel - Used, some holes - $10
Cluster - Stock - $75
2 Washer bottle W/lid - Used - $10 Each
Mirror control base - Used - $5
Door switch support - Used - $5
Pass marker light - Used - $35
Vacuum “T” - Good - $2
Shifter Cover - Good - $10
Pass Mirror - Good - $10
Intercooler bracket - Good - $25
Shifter - Needs spring - $20
Crank pulley - Good - $40
Alternator - Good - $60
Intercooler Bracket - Good - $25
Hood Latch - Good - $5
Door lock W/Keys - Good - $15
Bumper cushions - Good - $15
Chrome door handles - Good - $20
Intercooler Fan - Good - $40
Stock Injectors - Good - $20
E-Brake Cable - Good - $10
Radiator Support Bracket - Good - $10
Stock sway bar - Good - $25
Water pump pulley W/Bolts - Good - $25
2 Sill Plates - Good - $20 Each
Stock FPR - Good - $15
Inner window sweeps - Driver used, Pass New
Turbo J-Bracket - Good - $20
Bumper Strips - Good - $40
GN Upper door panels - Used - $30
2 Front Chrome Bumpers - Used - $75
Rear Chrome Bumper - Used - $75
Steel Bumper Supports - Used - $20
Coated Turbo Shield - Nice - $60
Stock Heads - Good, untouched - $100
Regal dash wiring harness - Some splices - $25
Regal engine harness - Some cuts - $20
Both GN Fenders - Trimmed for larger tires - $200
Stock upper trailing arms - Used - $20
Radiator - Used, still good - $50
Condenser - Used, still good - $30
Oil Dip Stick - Used - $35
GN Seats - Driver power, both need cleaning/recovering - $150
Cam Sensor Cap - Good - $20
GN Door Panel - Used, Faded - $40
AFTERMARKET
Aftermarket sway bar - Used good shape, dirty - $100
Chevy SSII Rims - Used - $50
Electric Fan - Good used spare - $50
Innovate wideband W/Controller - Good shape - $150
Jegs line lock W/Install kit - Still in wrapper - $110
Kirban Lug Nuts - Used - $50
2 Hood to fender bumper - New - $4 each
2 Hood to rad support bumper - New - $5 each
Rear hood to cowl bumper - New - $6
2 Hood to rear fender bumper - New - $4 each
Door pull screw covers - New - $18
Turn signal screw set - New - $3
Kirban rear seat frame brace - New/scuffed - $50
Dashmat - New - $20
RJS racing belts - 1 set, 1 lap belt - $15
Kirban magnetic drain plug - New - $10
Casper volt booster - Good used shape - $25
Twin A-pillar gauge holder - Good dirty - $10
3 Bar map sensor - Good shape - $20
Adjustable WG Actuator - Good shape - $40
4” Exhaust - Used - $275
Battery Box - New, dirty - $15
Digitails - New in box - $250
Autometer Tach - Good shape, long leads - $20
Complete "bolt-in" fuel system - Really good shape - $1000
Front Plate Bracket - Good shape - $20
Rear plate Bracket - Good shape - $20
Wiper electrical/Vac Line - No cuts - $15
Hood Hinge Bracket - Used - $5
2 Exhaust manifold gasket - New - $10 each
2 Open Stainless Bolt Kits - Some open, some sealed - $30
Rear coil springs - Slightly used - $30
Test Pipe - Slightly used - $25
Turbo Oil Drain Gasket (7) - New - $15
GNX style center caps - Busted, 1 good - $5
Boost controller W/Bracket - Plastic - $20
Boost controller - Metal - $20
PC8 Crank Position Sensor - New - $15
High Volume Oil Pump Kit - New, K20IHV - $40
3” Downpipe, Ext WG, Ext Dump - Used, 2 Dents - $350
FREE
Bumper Cushion - Shipping
Bumper Bolts - Shipping
Engine fuel line- End cut off - Shipping
T-Top lock covers - Chipped ends - Shipping
Door Insulation - Shipping
Driver headlight surrounds - Shipping
Seat Plug - Cut wires - Shipping
3 Door Sill Rubber - Shipping
2 Tail light plugs - Shipping
Cat converter Bracket - Shipping
Intercooler Shroud - Shipping
Bracket above rear - Shipping
Boxes of nuts/bolts/brackets/parts...If you need something specific send me a picture so i can match it and ill see what I have.
Send me a bill for the EGR assembly, upper and lower hoses, water pulley and bolts, radiator, Kirban magnetic drain plug, and the exhaust manifold gaskets.
Ok sorry just read you are selling the whole package. Let me know if you are willing to part and sell the parts I am interested in.
Are you only wanting to sell the entire package right now? There are several things I’m interested in but if I’m reading this correctly you don’t want to sell individual items?
If selling individual items I’m interested in electronic hvac, tail light harness, radiator cover, j bracket for turbo, turbo oil feed line and cam sensor cap.
if the whole package doesn't sell ill take the stock oil fill , stock injectors , rear seat frame brace
Interested in the intercooler shroud if it's in good shape and complete? Also the boxes of bolts
I realize it's free so I don't want to put you out, if you get a chance could you send pic of the cat bracket? I beleive it should be the hanger that bolts in front of the cat...If that sounds like the item nevermind the pic, just PM me. Thank you.
is the regal radiator top plate interchangeable with the cutlass top plate? i have an aftermarket radiator that was fabricated for the cutlass top plate, but haven't sourced one yet.
