riviera_turbo82
- May 29, 2007
Good afternoon everyone--
I wonder if anyone knows of a source, or someone with sufficient skills to tinker, to provide a performance chip for my '82 Turbo Riv? Many years ago, I had installed a Kenne Bell 1TXB cam in this car, and really didn't give much thought to the gas mileage. Fast forward to 2007, and gas above $3 a gallon, and now I am very sensitive to the cost of gas.
With the stock ECM and PROM and the 1TXB cam, the computer just keeps telling the carb to dump more fuel into the engine at cruising speed. I believe the lower vacuum reading from the 1TXB cam makes the computer think the engine is under heavier acceleration... all the time. I leaned down the carb, and even went to smaller primary jets and metering needles, but still can't get the mileage good enough to be "presentable". I'm averaging about 14 mpg, and not driving very aggressively.
Before I go the route of swapping back in a stock camshaft to satisfy the computer, I wanted to ask-- what are my chances of finding a performance chip or credible chip burner?
I had considered going the route of a MAP signal voltage modifier, but am concerned (with the turbo engine's going from vacuum to pressure in the MAP signal) that this approach may not be fruitful. Anyone have success in that respect?
Thanks, and best regards, Christopher Burns
'82 Turbo Riv, in Rochester, New York
