on the next batch I think i will machine the spring pocket into the top of the piston to eliminate the plastic spring seat.The new lo reverse piston is running too.ive got a new return spring assembly designed into it too and no steel apply ring ,just a solid billet aluminum clutch piston.im going to try to incorporate a ball capsule to eliminate partial apply when used with stage rite or with cross leaks into the circuit.
