Does anyone moderate this section?
John, I really don't see a problem here. There is a lot to be learned if you read between the lines...
There is always the option of not clicking on it.
SignUp Now!Does anyone moderate this section?
The dyno would even allow you to load the car in areas that most novice tuners would ignore.
I considered it, but the way I am, and learning a new fuel, I wouldn't of liked being under the clock. I took my time trying different ideas and thoroughly learning the fuel.Don, I may have missed it in the numerous pages of posts but have you ever considered a few hours of dyno time? I can usually get a new combo very close within a short time without the time and expense of track outings. I'm going again in within the next couple of weeks with the new motor. Lemme know if you wanna join.
scott wile
I've been interested lately myself. A dyno shop moved in right across the way lately.I couldn't agree more. One session on the dyno can save several trips to the race track. The dyno would even allow you to load the car in areas that most novice tuners would ignore. You can also tune areas that your chasis hasn't allowed you to reach (i.e. high boost) I would be very interested to see how much hp this car put down, no more calculators, no more simulators.
Don, if I'm reading your major plan right, you are attempting to build a extremely efficient engine using NOS to spool, with hopes it works better than anything ever done by the cookie cutter guys (comparisons sake).
Now, did you pick your CI by running the numbers through the calculator, or was that just made out of the parts you had laying around?
I have had 3 different converters in my car, the tuneup did not change much between a looser and tighter converter. I'm going to say that just because a converter is "looser" doesn't mean it's looser beyond the stall rate. From the description of the tuning you did with the tight converter, that should have been a hour (if that) project getting that tuned out. You chose the NOS to try and work around it and that is fine, and I can see that taking some tuning work, but it didn't work to fix the converter issue.
I see you are planning a S2 headed stroker project. Are you spending this much time with your current combo to learn tuning and other things, or do you think there will come a point you will just step up to more cubes and better heads (that will also help) before you put too much time into a converter that might not work (well) with your new combo?
If your goal is to run 8.50's at 158 I think you have enough to get there right now though...
A low stall TC would allow you to reach even more spots on the fuel map. Dyno or no dyno.The dyno would even allow you to load the car in areas that most novice tuners would ignore. You can also tune areas that your chasis hasn't allowed you to reach (i.e. high boost) I would be very interested to see how much hp this car put down, no more calculators, no more simulators.
There would be no use in putting it on the dyno for tuning the top end unless the fuel system delivery was increased. That will be looked into after I'm happy with the launch, the boost controller setting, and whether or not I can get the chassis set up to where it might take on more power.
It's very simple to look at what I've done, after the fact, and say that I would have seen the same phenomenon I was getting with the nitrous hit, even after changing to a different TC.Since you knew you were going to switch to a higher stall speed it really doesn't matter. You said yourself the tune didn't change much when you went to a higher stall. The inverse is also true. You could have done the tuning with the higher stall in and been addressing the other issues. (i.e. spoolup, chasis).
If the idea would have been to throw a quick race tune on the car, that would have come about much quicker. This being a learning project, I took my time and experimented a lot. And I mean A LOT.
If you watch most alky racers, you will see them change the oil every one or two runs, even with being towed to the lanes and back to the pits. With the fueling dialed in, a person can cruise to the staging lanes, cruise back to the pits after the pass without a tow vehicle, and go multiple events before changing the oil. That is the difference between dialing in a methanol fuel map and just throwing a quick tune on the car. Most of that also has to do with running an intercooler.
You are completly wrong. You will take a year to work on spoolup, etc.. and not do the same when dialing in your top end? When you put it on the dyno, you can change the A/F up and down and see what it does to the hp AT DIFFERENT RPMS. You can do the exact same thing with timing. You can also analyze the hp curve to determine shift points, convertor information, area under the curve, etc... I won't even talk about your boost controller settings.......
I have already said too much. A month from now, you will say you knew you were going to have to get it on the dyno and that you just needed to put the cart in front of the horse.
If you had any idea how much time I spent changing around the fuel table, experimenting with this and that, you wouldn't be saying that.At $50 an hour I disagree.
I'm not trying to say that dyno time wouldn't be nice. It's a nice luxury, especially if it's a customer's car that has to get out in a timely fashion.2 hours of dyno time is comparable to a full track day for me. I understand the difference in fuel regarding the tuning aspect, as I am undergoing the same process. I agree with your TC tuning concept but common sense and 2nd hand experience usually wins. I went to Dusty for a convertor for my new combo and without making a single run I'm betting it's too loose. Since my motor is based around a high velocity/low rpm exhaust design it currently flashes to 5000rpm in 3/10's of a second with zero boost. I'm hoping it has good coupling characteristics at a higher rpm(7500max)bute'll see. In the mean time I will test and determine what's needed but at least I'll have a good baseline and send the PTC convertor back for the free re-stall if needed.
BTW, at 2850 my 76gtq maxed out at 780rwhp. After installing the 47/88 I only picked 2/10's in the 1/8mi but the fuel map only changed in the 3500 -5000rpm area.![]()
I'm not going to get into teaching everyone the different aspects of different sections of the fuel table for different operations of the engine from startup to cruising back to the pits, but all aspects were studied after each pass.
You would not end up with a "better" tune. You would end up with a "decent" tune that would allow you to better judge whether the present TC was going to do the job for you or not.I really can't understand one thing that is bothering me. Why would it be better to tune with the wrong converter? If you can't tune a few cells in the table with the new converter as accurately, they can't be too important to accomplish a good running car. I would think you would change the mechanical combo as soon as you determine a mis-match so your tune can concentrate on the cells that will be most relevant when the combination is right. I really have almost no experience with tuning so this is a legitimate question.
A dyno is not necessary for tuning in idle and off idle, cold starting, warm starting, warm up enrichment, light loading, or testing different mixtures strengths under the previous listed conditions. There is a lot of preliminary tuning that takes up the majority of time tuning in a car that can be done very well without a dyno.If you stopped trying to teach and tried to learn a little, you might find that the advice that has been given to you is actually pretty good. You have several qualified people here TRYING TO TEACH YOU a few things. I think the frustration come in when you refuse to listen.
What I (and probably Scott) am saying is the dyno is not a replacement for the race track. It is just another tool that can allow you to get the car tuned. Like any tool, it is only as good as the guy using it. You had already said it would be of no use, yet had never tried it. I can just about guarantee you will learn something from it, good or bad.
You're right. I start most threads with the idea of treating it as a diary or Blog of my experiences with the car. Since I'm doing things that no one else in the Buick community is doing, I thought some might find it interesting to read up on what I'm doing. Judging by most of the posts so far, I think there are some that would rather I didn't share anything with you at all. I'm not sure why, but I get the impression that I'm encroaching on someone's territory or something? I'm not sure how I'm doing that since I'm doing things that I'm sure no one else is going to pick up and try themselves anyway.From what i can see and read this is more of a documentary on what Don is doing.
But he seems to request some input which always falls on deaf ears......
Maybe i'm wrong and sorry if i am......
