Aug 24, 2010 #1 S Sweet6 Well-Known Member Joined Jun 12, 2001 Messages 3,546 What bedliners do you guys like? Spray in or molded? Or anything else. Thanks
Aug 24, 2010 #2 toofastforyou 2FAST4U Joined May 25, 2001 Messages 5,785 Four years ago, I had my (then new) truck's bed sprayed with "Line-X"...Still looks new today! :wink: Claude
Aug 24, 2010 #4 R rmar Yo Baby Daddy Joined Oct 1, 2007 Messages 5,892 Spray, 2 part poly about 2500 psi hot. Good ****...:biggrin:
Aug 25, 2010 #6 T ttypewe4jim pa turbo buick racing Joined Dec 1, 2002 Messages 1,808 Spray in is the only way to go.... although I have managed to have a spot wear threw on mine it has held up very well IMO.
Aug 25, 2010 #8 S speedskills Seniór Member Joined Apr 24, 2010 Messages 335 Spray in. Make sure your bed gets a rough sand first and DON'T USE ZIEBART:redface:if you have one around.
Aug 25, 2010 #9 O O SO LO Well-Known Member Joined Apr 22, 2006 Messages 1,591 Line-X I've had for about 8 yrs- love it!!
Aug 25, 2010 #10 R Roc87 11 Second V6 Joined May 25, 2001 Messages 2,997 Had a Line X in the el camino, held up great, even quieted it down some. Wanted to get a spray in on the F250 when I got it, but found a used molded drop in liner for $40, used the $ saved to put toward a tuner
