SignUp Now!Originally posted by Dr. D
1. Since this is a GM unit, does it require mods for installation or
can you use the old brackets like most other GM cd & cassette
units?
2. Is this completely self contained or there an external amp?
3. What is the price for everything needed?
Thanks for the info, I like what you're doing to keep the original GM look. A couple more........
1. For the external amp, which lines out of the deck are you using
for signal?
2. Are you using an external switch for on/off or are you using the
antenna terminal to accomplish that function?
Thanks.
Originally posted by FlyinGN
hmmm. If ya turn off the antenna my amp will not come on.. Its fed off the pink power lead to the antenna.. right???
