Pinion Angle
Hognose
What should the pinion angle be set at in my car? Also are there any special tricks to setting it? Thanks,
Matthew
pioion angle
i read somewhere between 0- 3 degrees negative. should put you in the ball park. for a g-body that is. frank.
you have to change the upper control arm location...either adjustble uppers or reposition the stockers
stockers are not adjustable
you can adjust with aftermarket adjustable upper arms like edelbrock or hitchkiss or dshop2000 from ebay(im running with them dispite the possible frame damage they may cause)
or increase angle with slightly longer lower arms from hrpartsnstuff (i think they have them) ,
if your bushings are worn nothing you adjust will help as the axle will rollup anyway.
they also make adjustables lower arms but none ive seen allow for a factory type rear sway bar
you CAN use the stock uppers, but they have to be redrilled and relocated
pacecarta? frame damage?
Hi, what frame damage are you talking about with those arms? I was considering a set myself now you have me worried! Thanks
its somewhere on this site
http://www.vortexbuicks-etc.com/
claims the solid bushing uppers will mess up the holes at the frame mount point
for my uppers i have adjustables with solid bushed heim joints at the frame point but OE bushing at the axle ears , the nice thing about the ones i got is they dont have to be disconnected at one end to adjust
for the bottoms i have solid bushings (sleeved) greaseable arms (similar to the southside bars) , no rubber bushing but i can still use the factory swaybar with them
i got the uppers and lowers from ebay (dshop2000)
HRpartsnstuff sells weld in reinforcements for the frame points at the lowers . they also sell precut boxing plates for the arms and good bushings if you want to use the stock arms .
miy originals were just to nasty looking and my uppers had already egged out at the axle bushing bolt so i wasnt going to try to use them
Like i said im not too worried ,the fact that im running stock rubber bushings in the axle i feel i probably wont have any problems , and if a problem arises ill just wheel out the mig and fix it .
parts
Are you happy with the uppers and lowers as far as quality and "beefyness"? I though about getting those as well. thanks!
i like them . quality is great , and they seem beefy . the lowers are thin wall rectangular tube steel but thats needed for roll when you drive over something on one tire just as it is with the stockers, but they are square tube so they dont deflect like stockers .
if your stockers are in good shape the poly bushings and the boxing the lowers can do the same , i just sought an easy swap that wasnt much more $$ than doing the boxing bushings ,even if i was doing the welding . i had a pinion angle problem due to frame issues so the stockers werent going to work and adjustable was the only way to go for me .
with the hiem joint the uppers arent in any way bound as they can rotate at the heim fitting .
wish i could have had lowers built similar to the uppers (frame end heim joint ) even if they were still fixed length so the sway bar coulds be retained and to allow for more unrestricted roll on them (help to prevent bindup which can cause unpridictable breakaway under power in the turns ), they offer adjustable heim end lowers but you need to run something like the hrpartsnstuff bar or the wolf style race bar (they sell them on ebay) .
i do find i need to tighten the bolts on ther lowers up every so often so i may do something to keep the nuts tight (like double up with another nut) and they did need some time for the grease to get worked in (grease them before install will help), otherwise all i notice is no more axle wander and much less front roll
i dont do a lot of miles on the GN and i not going to go to all out drag race setup ( tall soft wall tires , soft drag shocks and the no front bar , big rear bar to make up for the front , makes for a unenjoyable road car
im working more for street /autocross , tight steering and predictable control and good braking , the car was a handfull when i bought it with the worn out bushings in front and rear . new bushings , the bars and 16" wheels really tightened it up .
Matthew
The Alston Chassis Manual, and Dave Morgan's book, *Doorslammers*, actually explains it. ie how using different angles increase/ slows down the axle rotation, and what that does to the contact patch/ adhesion.
What do you guys think about the UMI adjustable upper control arm and lowers?
