When I bought the car off the original owner, it had 2 pinstripes down the side and some marking behind the rear seat window. The colors match the turbo 6 colors, but I don't like the way it looks. Any suggestions on how I can remove them safely?
Stuck on: finger nail, heat gun, plastic razor blade and the use of Goof off or mineral spirits to remove the sticky. 3M does make an attatchment for a drill that is basically a big eraser. If you're carefull it will rub the stripe off.
Painted on: wet sand off (requires buffing), sometimes laquer thinner will remove but you have to be really careful.
If none of this works and you're worried you might damage the paint then I would take it to a very experienced detailer or body shop. Hope this helps.
