for you guys that have pinto racks, i noticed that on winsett's car that the rack is offset to the drivers side, i plan on running a pinto rack, and it seems that with a stock crossmember ( or at least the outer portions) that you have to offset the rack to make a clean shot threw the member, does this lead to any handleing problems due to offsett pivot points that differ from the axis of the lower control arm, i would think that bumb steer would be an issue, or does limiting the front suspention travel for the track also make the issue minimal due to much less travel, thanks for any help.
Grant
Grant
