piston/rod install help!
1000MileStylez
Black Sheep
I have JE SRP pistons on crower rods. there is no tag to mark the direction the rod faces or the pistons. Only markings are the cylinder numbers on the rod/caps. On the crower rods when you split the cap one side has a bigger chamfer then the other looking at the profile. is there something i am not seeing?
im reading the tangs should face towards the outside of the block, meaing the motor mounts on the respective side?
[/IMG]
Where the numbers are stamped on the sides of the rod is where the tangs are on the rods
