What reference are you needing? Regardless, you still need to measure EVERYTHING......twice. Pin heighth, rod width, rod length, deck heigth, ring pack, back up oil ring or pin plugs, CC of combustion chamber, head gasket CC, bore diameter, stroke, dish depth, crown thickness, pin diameter, pin weight, taper wall, or drilled pin, dish or reverse dome, desired compression ratio, alloy. That just about does it.
