eastwoodad
- May 23, 2003
do any of you guys have any experience/knowledge on piston to valve clearances on the n/a buick v6. I will be using a stock turbo crank, speed pro powerforged pistons, 1.77in. 1.5 ex valves, a .490ish lift cam, and a steel shim head gasket. i know these are a low compression "turbo" piston and they have no valve reliefs. i do plan on milling the block and heads to bump the compression up....how much do you think i can before i will have piston to valve clearance issues?? thanks so much.
Aaron
Aaron
