Pistons
87TIGN
Death by boost
Are Federal Mogul forged aluminum pistons good? I just got a set from Postons.
-Andrew
Trw pistons are tuff as hell, and a great bang for the buck, but they are a little on the heavy side, especially the pins, but they are a great entry level forged piston.
I run them. I had my rotating assembly balanced and everything worked out well. If your goals are for a mild street/strip engine like mine then they should work well. I used my stock crank and rods too. Supposed to be good for 600 hp.
-Andrew
do they have some numbers in the pin area on the side? if so, do you mind posting them? I want to know if the pistons from my engine were from poston. Thanks.
They should be here tommarow and I will post any numbers for you than
Isn't it a little too late to ask if they are any good... if you already ordered them ? :D
Haha yes it is too late but I would have sent them back had I got bad feedback about them. Didnt know TRW produced them tho. TRW rocks
