Plastic vacuum lines
jdpolzin
Hello, just a couple small parts. I need the plastic vacuum line that goes from the metal line off the vacuum block to the top of the fuel pressure regulator. It's L shaped and has a straight rubber gromet on the end that pops on the metal line and a 90deg rubber gromet that pops onto the regualtor. I also need the two clips that hold the vacuum lines on top of the AC box. And lastly, I need the plastic vacuum line that goes to the heater control valve, this one is held by the two clips and goes down between the fender and inner fender. Thanks -----Jeremy
