I'm going to put all the stock hotair stuff back on.
No,put the 30s back on. If it runs good,you can suspect the 009s. If it doesn't,something else is wrong.
SignUp Now!I'm going to put all the stock hotair stuff back on.
If you put the 30's back in, make sure you use a chip for 30's (or a stock chip).
Why? Your chip will run these just fine,but not at WOT. He said it ran fine before with the 30s and the 009 chip. If he puts the 30s back in and it runs fine,we can suspect the 009s. I don't think the 009s are bad,but this would be a good and simple test. What do you think?
This is what I'm wondering.If it's not too lean, then maybe the MAF is out of calibration (too high).
I would suspect that it seemingly ran good (idle/cruise) with the stock chip and 42's is because such a combo would be running VERY rich, which could mask other problems.
