SignUp Now!Thanks! what do you think about Car #2 1/4 time wise? I am mechanically inclined and have had projects in the past.One of the things I didn't mention was they both appear to have (or you didn't state that they didn't have) flat tappet hydraulic cams. Most people on here will tell you that you are at a decent risk of "wiping a lobe or lobes" on hydraulic flat tappet setups these days. Some believe it is directly related to the oil formulations we have today vs 20 years ago. The tree huggers have forced the oil manufacturers to remove certain chemicals like zinc from engine oils that some feel really helps flat tappet cams live. This issue is not just limited to Turbo Buicks.... it is affecting everybody. With that said, understand it is between $750 - $1000 to convert a turbo Buick over to a hydraulic roller cam. IMHO, anyone that currently is having issues with wiping lobes, or is building a new engine.... ought to pony up and go hyd roller....
Also, I disagree with the above poster about buying a stocker. It is money well spent to go ahead and buy one that has most of the "extras" you would likely need anyway to run the number you want. It will save you money and time.....
As far as potential.... the car #1 has high 10 sec potential..... on a good tuneup 26psi or so boost and a good 60' time.... with good air. It should get into the 11's on low 20's on the boost with a mediocre 60' time on any given day.... if the tuneup is there. There are too many details missing on #1's 12.6 @ 109 time to accurately decide if there is an issue. My car went 12.7 @nearly 108 the first time to the 1/4 mile track with a few bolt-ons and a stock turbo on low 20's for boost.... and it had knock the entire way down the track...... It could have gone bottom 12's that day if I had a decent tune... but I hadn't had the car but about 6 months and never been to the track and didn't know what to do to tune it properly.
With all that said.... there is a learning curve with these cars, but you can do it. The easiest way is to find someone locally that knows these cars good and can help. The next best thing is reading and asking questions here.
Good luck.
I have a question no one asked . Will this be your first hot rod , do you have any mechanical inclination . These are not stock cars you are buying and will take alot of knowledge to tune and maintain . These are pretty much race cars at this point and will take money to maintain . I am working towards getting my own car to 12.5 . I bought a clean low mileage car and building what I want knowing whats in it . Take the advice you have heard over and over . Find someone that knows these cars and have them look over it for you . To take a ride and haul A$$ means nothing .
My advice take you money buy a clean car and build your own .
AWESOME site!!! I have been on corvette forums, pontiac firebird forums, nissan forums, etc... but NONE of them have been this interested in helping a member of the community! This alone makes me want to buy a TB! THANKS SO MUCH GUYS it means a lot...tear...LOL seriously though you guys ROCKBoosted cars are kind of a different animal. With boost it only take a second to make a pile of junk. TBs have some weak areas that may need addressing; fueling, grounds, vacuum leaks, MAF, coil are typical. Even on a car that's modded with new or replacements doesn't nessassarily mean the car is up to snuff. Theres some good info here too: http://www.vortexbuicks-etc.com/
Rock n Roll man! Love the advice and help! CAN NOT WAIT!I'd say car #2 could also go well into the 11's with the PT51 on race fuel (I didn't see where it had an alky kit). This is a similar turbo to the much loved TE44 except a T350 exhaust wheel which is sort-of a mismatch with the compressor wheel. Car #1's turbo has more potential. If I bought car #2, I'd buy an alky kit (Razor's) first thing...and a new TT alky chip. Id work my way up to low 20's on the boost with some tuning help from someone familiar with the tuning on these cars..... and see where you are and go from there. You still should be able to go into the 12's on straight pump gas with that setup probably, but it would be much easier with alky. However..... if the tuneup and traction are off..... you might not even get into the 13's...... so get some help and learn all you can..... it makes night and day difference on these cars.
IMHO, both seem like really nice cars...... I'd like both in my stable.
I was on the Nissan Maxima site for several years. Bunch of boneheads.AWESOME site!!! I have been on corvette forums, pontiac firebird forums, nissan forums, etc... but NONE of them have been this interested in helping a member of the community! This alone makes me want to buy a TB! THANKS SO MUCH GUYS it means a lot...tear...LOL seriously though you guys ROCK
FACT hahaI was on the Nissan Maxima site for several years. Bunch of boneheads.
st.louis, moWhere are you located?
THanks!A car with mods that is slow could be due to a failing fuel pump. Walbro had an issue a few years back and has affected a lot of our cars. You should check out both cars at WOT (wide open throttle) with a fuel pressure gauge to make sure fuel pressure rises 1 psi per pound of boost. Running lean could cause head gasket failure and detonation. Ask the owners how old the pumps are. I just had to replace one last week and supposedly it wasn't part of the recall. The people who say you should get a stock car is because they are trying to tell you that probably both of these cars have been beat on. GN's hold their value better than T-types, even if you personally like a car with color better than all black. You have described these cars pretty good but haven't mentioned miles and price so it is hard to make a recommendation for you. Also, when the car with ghost flames was painted, you should find out if the old paint was sanded to bare metal or not. Could be the difference between paint lasting 20 more years or two years. Good luck with your purchase!
