Scottie-GNZ
- Jun 14, 2001
SignUp Now!Originally posted by Scottie-GNZ
Thanks folks.
I think we can definitely conclude it has a P trim turbine which the 62, 63 & 45 uses. Like Kendall pointed out, the compressor side is using the 6-blade wheel, unlike the 61 & 62 but it does not have a 4" inlet like the 45. .
Originally posted by DR BOOST
THE TE SERIES ONE IS A 62
WTF IS THE TA ONE. that is the first time i have seen a 4 bolt housing with the internal wastegate side.
surej
Originally posted by Nocooler
The 4-bolt is a T-3 from a turbo ford.
Damn, thanks Louie.
If the 62 & 45 both have the same turbine side, is there any difference in how they spool up? Will this be too much for my setup? +.020 3.8L, Champion Irons and matching intake, stock cam, FMIC, AC 9.5 32-3500 LU. .........a dog spooling up. Just looking for another 35-40hp over the 51.
Originally posted by TurboDave
Really? I thought it looked more like the turbo off of a 79 Turbo Coupe, but I really don't remember what kind of turbine housing they had. I know the compressor bolted to the intake and the compressor inlet sucked through the carburator.
