please help! (taillights and turn signal)
ll3lue
basically it's like this..the interior is fully loaded and every option works and everything is great..EXCEPT for the right turn signal...when i put on the right turn signal the lights come'on but also 2 small lights on the left turn signal come on as well and they also click fast ..now when i do the left turn signal everything works like a charm...and with my headlights on i think my right brake light doesn't work either...im gonna try changin the bulbs..but if that doesn't work..i dunno what to do *sigh* :confused: :mad:
Section 1 said:
I have the same problem, I have been ignoring it :mad:
Section 1
okay now there is 2 of us! can anyone help me and section 1?? please..this sucks..
I've heard that this can be caused by the switch inside of the turn signal lever wearing out. I know it happened for me, but that was worn out on the hi beam lo beam switch. Remember, these cars are 20 years old and switches die in time. I never fixed the problem, I sold the car shortly thereafter.
If you have a steering wheel puller, you should be able to pick up a lower mileage part from nearly any G Body for a couple bucks at a junkyard. Give it a shot and let us know if it works.
could it be anything else?
After reading it, I need a little clarification.
"when i put on the right turn signal the lights come'on but also 2 small lights on the left turn signal come on as well and they also click fast"
What two lights are these? I originally thought you were talking about the lights on the instrument panel.
Replace both 2057 bulbs right rear, and see if it still does it.
One may be in wrong, or be burned out and is shorting with the other connectors inside the bulb.
the rear taillights, if i make a righthand turn it clicks faster then when i make a left and the lights come on kinda dim on the right and side and 2 small lights come in on the left hand side...but this is only with making a rightturn..if i make a left everythign works perfect.
Check to see that you have the proper bulbs in place. The different resistance will create gremlins in the system.
