BlackMagic
- Nov 20, 2003
I'm around Little Rock, Arkansas and need to find a good shop to tune and/or fix my car within about 300 miles of me. Any really good shops around the Memphis, Tulsa or Dallas area? I can drive the car there and leave it. Memphis would be great.
I got into a big mess when I bought my car. The person I bought it from claims that it was running perfectly when he dropped it off at the shipping company, but I have found waaaay too much evidence to believe him at this point. There was even a thread posted on here describing the exact symptoms that this car is having where the previous owner was supposedly diagnosing a "friends" car. When I pointed the thread out he promptly deleted it. ( I did save it before he deleted it though.) When I 1st got the car and wanted to ship it back at my expense due to the terrible way it was running ( I would have been out $1800 for the shipping both ways ) he basically said he was not responsible for my car. I am having to suck it up and spend a lot more money than I planned. I paid top $$$ for it expecting it to be running right, and got screwed. Merry Christmas for me and my family....
1st off the turbo was bad (dumping massive oil into the downpipe and looked like I was fogging for mosquitos.) I replaced the turbo and fixed the smoking problem (also replaced the o2 sensor while I was at it since it was soaked/caked with oil.)
I also replaced the plug wires while I was at it, and found one plug that was very loose and came out with only about 2 full turns.
The engine still has what seems like a very bad vibration (like something is out of balance) and it idles really crappy (missing). When you give it some gas and the boost starts coming up, the boost gauge needle fluctuates back and forth quite a bit (not steady at all...maybe has a good 5-7 psi fluctuation.) When the original turbo was on it would swing back and forth from 0-12psi when you got into the boost. I think he said the boost was set to 12psi max. Hooking up a vacuum gauge gives me a vacuum reading from 14-17 with the needle fluctuating up and down. I can hear the EGR valve? (plugs into the intake on the pass side kinda in the middle down low) making a clicking sound pretty regularly while it's idling. BLM's are around 128-135. It has a bstc boost controller hooked up. Fuel pressure is 44psi line off. TPS is at .42-.44 at idle. It had 42.5lb injectors now.
I am getting new injectors (57's) and a chip (extender extreme and a T+) to match the turbo I just put on (T64E), but don't have the time to spend tuning this damn car. It sucks that I'm even having to fix it, but I want it done by someone who who knows what they are doing. I just want it tuned!
Thanks,
Shawn
Thanks,
Shawn
