i am unable to load pictures since the site has change, so I wrote the #'s down. First time logging with the PL. This car is running 93/alky
4600rpm
83mph
788 02's
25.2 boost
Af 11.37
19.1 timing
Zero knock
4700rpm
87mph
784 02's
24.8 boost
Af 11.34
19.1 timing
Zero knock
4750rpm
91mph
22.1 boost
780 02's
Af 11.29
19.1 timing
Zero knock
02's are dropping as the rpm's go up. As well as the Af's. Also the boost is dropping too. Don't know why that is going on? Let off the gas at 91 mph. Did take out two degrees of timing before this run. Do I need to take out more fuel? Did take out four % before this run, because the BML was 118, after that the BML was 130, before this run.
Thanks for any help
Ray
4600rpm
83mph
788 02's
25.2 boost
Af 11.37
19.1 timing
Zero knock
4700rpm
87mph
784 02's
24.8 boost
Af 11.34
19.1 timing
Zero knock
4750rpm
91mph
22.1 boost
780 02's
Af 11.29
19.1 timing
Zero knock
Thanks for any help
Ray
