Sweet!!!!!!!! We need one.....
What about the VSS??? use the orginal/factory??
The prototype uses the factory VSS buffer pickup affixed to the speedometer using a special plug with mounting bracket. This is still up in the air as the SW speedometers need to be modified to accommodate the VSS pickup, i.e. hole drilled into the case to focus on the speedo magnet reluctor.
Hopefully final production will have this feature which would make it a real simple installation. It's all about working with Stewart Warner to access the speedometer housings prior to final assembly.
However, if not, the in-line Hall-Effect pickup and modified VSS buffer will be plan B.
