SignUp Now!Great tip for larger wires or breakage of the old looms. You can always teach this old dog a new trick.
Ah... That's easy!
Why couldn't I figure that out?
Thanks.
Maybe you were really tired?
Yeah, that must have been it!
If the wire separators you get are like mine (I got Taylor's 10 mm V6 kit) you can attach them to the original metal brackets by drilling the blind holes on the bottom part of the Taylor separators all the way through. Make an 1/8" flat aluminum plate only as large as necessary with holes to match the searators (only do the ones that attach the the metal brackets).
You will use machine screws with the head of your choice, I think 8-24.
I tapped the holes in the 1/8" aluminum plate, but you could put nylocks on the bottom.
Pull the stock plastic holders off the metal brackets and enlarge the notches on the sides with a die grinder (the metal brackets are hardened spring steel).
Install the Taylor separators on the wires with the longer machine screws going through the separator halves and the notches in the stock metal bracket, with the aluminum plate on the back of the stock metal bracket sandwich the stock metal bracket in between the bottom separator and the aluminum plate and tighten everything down.
I'll see if I can get an up close photo.
Holy schnikies, Scooby! That sound like a lot of effort just to save $12- $32 dollars.......
Jus' sayin'.......
http://www.jegs.com/i/Taylor/895/42829/10002/-1?
https://www.amazon.com/Taylor-Cable...90782&sr=8-15&keywords=taylor+wire+separators
It's not to save money, it's to have the larger wire separators attach at the factory location and not all willie nillie.
No kidding. On another forum that I frequent, one members sig is something along the lines of: "Today you are older than you've ever been, yet the youngest you'll ever be"
To that I'll add ...And possibly the most tired.
PS. Good job on your wires.
Well, that makes sense then.
