Any advantage to plugging the "F" hole on the TCI plate, some kits do some don't. FWIW I have the 3-4 accm blocked.
Anyone here using the TCI kit? if so did you use the spring or the pin in the line bias valve. Thanks.
I like the TCI plate. I drill the L/U hole in the plate and grind a pin to .870 length to replace the spring in the line bias. Only use 1 check ball in the VB. Isn't there 2 different levels you can do with that kit? Don't remember which I do and it is too cold to go look. Don't remember reading anything about plugging a hole.
If I remember correctly, "F" is for the 3rd accumulator. You would have to take the teflon ring off the accumulator piston inside the servo and plug the bleed hole in the 2nd piston. Lot like the TransGo kit.
