SignUp Now!My autolite 23's were white. I just put in AC CR43TS. I have your alky and Eric's chip. What would you recommend? Thanks.Razor said:Plugs should be tan'ish
White=lean
Black=rich.
After going thru 5 gal of VP methanolGNRick said:My autolite 23's were white. I just put in AC CR43TS. I have your alky and Eric's chip. What would you recommend? Thanks.
Razor said:I'd be looking at your BL numbers and make sure you dont have a vacuum leak. Or fuel is dropping out. White=BAD.
If at WOT the O2 numbers are rich(lower 800's) and you have white plugs.. more than likely your issue is an air breach.
HTH
